Wel...still have the problem...z won't start,I try everything to finish...but nothing..this is what I did alredy ECU...is fine.. Because I have 3 good working and I test the three PTU is fine because I test 3....also I have spark in the injectors CAS... I thing is fine..because I test 2 I know they fine...also I have fuel pressure very good.....I try couple things some guys from this web site talke me (thanks for the tips) but still with the problem........NOTE...the problem is...no pulses in the injectors? But I found power in one side(wire) of the plugs of the injectors...But the another side(wire) has to be a ground to this work rite? O how this work? Well I found this wire don't make ground on the six plugs....so when I check with the multimeter.. Have between 12-14 volts... But only if I read the wire with piwer and ground from the chassis or engine....NOTE-one wire of the plugs of the injectors have to be ground..if it is....why this are not reading ground?
